I was in the "fill the pool with an inch of water to see if it's level" stage when I noticed water coming out from the bottom of my new Intex. Great. My first attempt with an Intex and I have a leak after 1". I am going to try to locate the hole (via sunlight, per above) and a dye test, though I don't know what that is exactly other than dropping in food color (which I hope doesn't stain) where I suspect the hole to be and watching. I bought some showerpan liner pvc cement and will try the patch kit sent with the pool. 'Sort of wondering if I should have bought the wet/dry pvc cement instead.
I am grateful the leak was apparent after 1 inch instead of after filling the whole thing...
