4 foot spa brush?
wsamon
0
Mar 16, 2015
142
Largo, FL
I apologize in advance for this silly question.
We have an attached spa. I've always brushed it using our 20" (?) pool brush. Apparently, my wife wants to start helping too but the big pool brush on the 6' long, 1" diameter pole is too unwieldy for her. Are there any brushes designed to attach to the same 4' long, 1/2" (?) diameter pole as the spa leaf skimmer? I'm having trouble finding anything. It's fine if it come with its own pole.
This is a 5" brush. Just take an existing pole and cut it to your desired length. Tape the top to make a handle.
Not sure how long you had your poles but over time the lock stops working or something gets bent. Renew it by cutting the lower half to use for small pool chores.
yeah, our 12' telescoping pole cracked in half the first couple days we used it. The pool had so many leaves on the bottom that the pole couldn't handle the weight as I pulled up full net after full net. We've been using it as a 6 ft pole for a while now. I've been meaning to drill holes in the other end to attach things to it. That would probably work for this. Thanks for the idea
