3rd summer with pool but first time here
lukerack
1
wetumpka, AL
Name is Luke
Have a 33,000 gallon liner pool with a Hayward sand filter.
I have a ton of trees around me and the leaves are unmanageable between October-December so I cover it
Always get my pool blue for the summer but I do feel like I spend a ton of money on liquid chlorine, Algaecide each week.
Not sure if necessary but I shock the pool once a week with 5-7 gallons of liquid chlorine
But I recently just bought an HTC 6-way test kit…no idea if that’s good or not.
Really look forward to saving money
Main things I struggle with:
1) keep weekly maintenance prices down
2) how to keep pool relatively clean during winter months while it’s covered (due to TONS of leaves that fall)
For the leaves, get a leaf net to go over your cover, once the leaves have finished falling, remove the leaf net so they're not rotting in there til you open.
I used the HTH 6 way with the addition of a Taylor FAS-DPD test kit for years. Bought a Taylor k1003 last year to go with the FAS-DPD which, for my purposes, gives pretty much the same as the Taylor 2006 kit. I don't test for CH as I have vinyl liner and it's not critical. What is critical is having an accurate free chlorine and combined chlorine, hence the FAS-DPD which the HTH kit does not give you. Also, the Taylor kit allows you to correct high chlorine levels to get accurate pH. I recommend you read the Pool School and down load the Pool Math app - very, very helpful. Will save you money from just indiscriminately dumping loads of chlorine.
