Stains and black algae
Feb 22, 2012
1
Had trouble with pool last season, it needed to be drained and water changed. Unfortunately the water sat it the bowl for several weeks till I could get to it. Did an acid wash but the bowl is stained and need to know if there is anything else I can do. I know that it needs to be redone but it is going to have to wait another season. Anything else I can do? Thanks
Put some water in the hopper and take a trichlor puck and hold on a place for a few minutes. If it lightens the stain then keeping the FC high for a while will help. If it doesn't, then take a vitamin C tablet and hold on a place and if it lightens it then it's metal staining and you can perform an ascorbic acid treatment on it.
Have you used that deck brush on it yet? Perhaps a good scrubbing with a common, mildly abrasive cleaner like Comet or Ajax will remove some of it.........you may have multiple things that have caused the stain.
After a good scrubbing, then I would suggest identifying the remaining stain as Bama outlines above.
