Thread: Stains on liner
    Stains on liner
    I have a 28' round AGP. I did not use a cover during the winter. There was a pile of leaves in one spot where the current of the water piled them up. I cleaned those out & my liner looks brand new in that spot. Every where else looks real dull or almost stained. The patter of the discoloration or stain of the liner is sporadic. I've tried brushing but it doesn't help. Is this something that will go away when the chemicals are balanced?
    Gdog
    28' round 23k gallon AGP Vinyl Liner
    1.5 hp pump,Sand Filter,Polaris 65 8 gallon Liquidator
    If you have a trichlor puck/tablet, try rubbing a small area gently with the trichlor and see if the dullness goes away. If so you will need to shock the pool and that will take care of it. If that doesn't work there are some other things you can try.
    Liner Stains
    Thanx Jason I'll try this & reply back with results.
    Gdog
