I am looking at replacing my 1 HP Whisperflo with an IF VF.
With my current setup, I have to crack the skimmer line about 2/3 closed to run the suction line on a Barracuda G4 cleaner.
Will the IF make it where I don't have to close the skimmer as much, or not at all?
I'm hoping I can open the skimmer line more.
If so, can I set it up to clean with the skimmer partially closed. Then run it low speed to skim, then kick it up on a schedule to clean and not have to change the Jandy valves?
