I recently moved into a house with Salt water pool. I need help with one of the valve, which I think is the water coming to the pump from pool. It is set to close. I was wondering if there is any reason for the valve to be close. Could it be something else rather thn the water coming to pump from pool (Picture included).
I have 2 skimmers, multiple returns to the pool. 1 Drain at the bottom.
Its the valve on the right on the picture.
Thank You
Thank You
