diyguy said:dont know your local rules DIYGuy, but in my area that would not pass. The bonding in my area has to be #8 BARE solid copper, and attach to four points around the pool. Also, the equipment would have to be on a raised pad like an A/C unit with 6" bare pad all the way around equipment. I didnt know about the expansion coupling though, learn something new every day
I'm a electrician, and have never heard of a slab for the filter/pump being code required, for an above ground, and I have friends in the trade all over, block is fine around here, I'd like to know what area your in that sounds tough do you have the inspector's general number, also that wire in the photo is #8 and of solid copper, I would be shocked (no pun intended) if your local code, only required a bare wire, sure that's not a misunderstanding of some sorts?.
Gary
Not necessarily a slab, the important part about that being (as the inspector told me) having space all around the equipment so it can be jostled and not fall off the support (or vibrate off). You might be right on some difference for an above ground vs inground though I dont see why it would be different. I was going over plans with the inspectors for an inground.
Just repeating what the inspectors told me to try to help anyone avoid a BS rejection over nits.
I am in the BR, La area covered by their inspectors.
all that said, whats said in the meetings and what is enforced in the field seem to be to completely unrelated things, as most inspections I have had the inspector was not in any way a nitpicker, and unless something was blatantly unsafe they said "fix that" and passed anyway.
