Solar Pro II
MK1985
68
Barron Wisconsin
Just hooked up a Solar Pro II to try and get a little more temp into the pool, we only have a solar blanket now. My pump is on the north side of my pool so I needed to build a platform to mount the coil, so the coil is at water level. When I started the pump I noticed the pressure runs a little higher then before and the skimmer basket isn't getting pulled down as much. Is this normal or is there something I should look for?
