Yep! And it’s amazing! I did the calculations and it should only be a couple hundred per month to keep it at 82 or so. I also bought a inkbird smart outlet that is on a timer in the middle of the night. Between 2am - 8am, it turns on, measures the water temperature. If the temp is below a set number, it turns the pump on which automatically turns the heater on based on water flow. I have the pump set on pump only and no chlorine so it will run as long as it needs to. When the desired temp is reached, it shuts the outlet off and the heater turns itself off. I even got the led intex lights hooked up to a wireless wall switch so I really feel like this pool is pretty legit. Totally happy! Oh and I also made a bypass so that when I need to run the chlorinator, it doesn’t go through the heater as the heater company says high chlorine is bad for it.
So what was your solution for bonding the heater with an intex pool?
