Results 1 to 14 of 14
Thread: SOS pad on steps = now rust
    Central Texas
    41
    Man I feel really dumb!!!
    I own a vinyl-liner pool and there was lots of stained dirt that was really hard to remove off the plastic stairs.
    I finally found a solution and that was to use an SOS pad to scrub off the dirt off the stair case. It came out and worked.
    BUT--- now I have a problem. The stairs got rust and is stuck on the stair area. I back washed as far as I can go. All the steps have brown rush all over the stairs. I tried everything to remove the rust stain on the stairs. I even pressure washed it and it's not coming out. Its bad!! Real bad!!
    It rusted b/c I have an SWG and the SOS pad has metal element in it, that is what caused it to rust. NOW I feel like SOL.
    Guys, I really need to know what to do to get off the rust off the stairs. Any ideas?? help....
    :grin::grin: Yes I am a newbie :grin::grin:
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    Central Texas
    41
    I scrubed w/ LCR w/ green pad. No go.
    I am thinking sand paper now
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Jun 2007
    SF Bay Area
    441
    Pool_Mike,
    Sorry to hear about your rust problems.
    Can you post pictures so we can get an idea of what you are dealing with?
    Good luck.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Central Texas
    41
    Titanium,
    Sure here are some pictures I just took. Its stubborn stains of rust.
    --- But I am thinking this product may work:
    http://intheswim.com/Pool-Chemicals/Poo ... y/#reviews
    Here are the pics:
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Try taking some crushed vitamin C tablets and putting the powder in a sock and gently rubbing the areas with metal stains. You should see some change within the first minute, if you don't we will need to try something else. It may take a couple of applications, but very likely that will lift the rust stains off.
    Central Texas
    41
    Jason,
    Ok, I'll try that.
    Also I was told by our local pool shop employees that I should use a lime or lemon and rub it on the rust stain and see if it came out. I did and it was a NO-GO
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Central Texas
    41
    Jason,
    My pool is full of water on the stairs. Would I have to drain out the water around the stairs to try what you told me? Thanks
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    No, you don't need to drain the water at all. The goal is really to get some vitamin C to dissolve in the water right near the stains. Putting the powder in a sock is an easy way to control where it dissolves.
    Central Texas
    41
    Jason,
    Well I tried the vitamin 'C' in the sock and smashed up the vitamens in the sock. Its a no go.
    I then went to the pool warehouse and they recommend a 19.00 product made by GLB - called STAIN MAGNET
    Here:
    http://www.ameri-brand.com/php/pool-sto ... magnet.php
    That did not work and now out on 20.00 bux and now I have a lot of vitamin C pills (but thats good for me, guess I was lacking in that dept)
    Any other ideas??
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Central Texas
    41
    You think this would work?
    http://answers.yahoo.com/question/index ... 026AAtGYgs
    Or how about direct Muratic acid on the stains? Maybe just pour little bit of muratic acid in the step area?
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Central Texas
    41
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    The next thing to try is a trichlor tablet. Gently rub a small area with a trichlor tablet and see if the stains fade at all.
    Central Texas
    41
    I have yet to try what you mentioned above, however---- I did buy this one product that is in a little sac/soc that contains oxalic acid. I purchased two packages and what your suppose to do is lay the soc over the rust area and let it sit w/o the pool pump NOT running and it suppose to remove the rust. Well, I tried it and it works, but only on the spot I laid it at.
    Only bad thing is that these little oxalic acid soc's are only about 4" x 4" in size. So I will need to lay a **** load of these out. Now, is this the best solution? I want something that I can get that is comparable and work as efficient as these little oxalic acid socs does. What do you recomment?
    (By the way, these little socs I had to do nadda, but lay the soc over the rust stain and let it site / no labor needed)
    Also is oxalic acid harmfull to skin or anything else in the pool?
    Thanks
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Central Texas
    41
    This is it, right here:
    http://www.swimpool.com/products/spotting.htm
    I just need more of it. Lot more of it. HELP!!
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
