JoyfulNoise, along those lines, here is what I think is the up to date full version of what you are doing, with a couple of questions that I would love to have answered at the end. maybe you or Chemgeek can read through and tidy up for me.
Chemicals Needed
Taylor R-0007 - Part of TF-100
Taylor R-0009 - Part of TF-100 TA Test
Taylor R-0010 - Part of TF-100
Bromothymol Blue (BTB) -
From Amazon
Mannitol -
From Amazon
Test Procedure
1.) Collect a 25ml sample of pool water .
2.) Add 2 drops of R-0007 to neutralize the chlorine
3.) Add 5 drops of R-0009
4.) Add 6 drops of BTB until the water turns yellow.
5.) Add 2 drops of R-0010 until the water just turns blue.
6.) Add 1 level spoonful (1/8 teaspoon) of Mannitol. If the water has boron/borates, then the sample will turn yellow.
7.) Add R-0010 drops until the water just turns blue. Record how many rops of R-0010 are used.
8.) Calculate ppm boron/borates by multiplying the number of drops of R-0010 used only in step 7 by 7.9 for total ppm
Alternative Test Method
1.) Collect either 25ml, 44ml, or 50ml
8.) Calculate ppm boron/borates by using these formulas
For 25ml sample, each drop of R-0010 used only in step 7 equals 7.9ppm
For 44ml sample, each drop of R-0010 used only in step 7 equals 4.5ppm
For 50ml sample, each drop of R-0010 used only in step 7 equals 4.0ppm
Questions About Test
1.) The level spoonful that was mentioned, is that the scoop that comes with the TF-100 kit for the FAS-DPD test, or is this a new measuring device that was added to the kit?
2.) Is the use of Boron and Borates synonomous?
3.) For the Mannitol powder, would it be possible to buy
this one which seems to be the same, just 4 ounces rather than a pound, so it is a bit cheaper.
4.) For the BTB, there is
this option that is 0.1% rather than the option which is 0.04%, so perhaps this is better. The downside is that I am not sure this type of bottle dropper will work well or not.
