Here are my numbers for about 5 minutes ago...
FC 4.5 (added two 96 oz jugs of bleach after test)
CC 0
pH 7.5
TA 140
CH 193
CYA 46
Temp 84F
Appearance=cloudy
Your pool should be clear by now. I don't think the colorQ has a good reputation for accuracy in CYA testing. What did you get for CYA when you used Taylor's?
If your pool is still cloudy today and you do not see NOTICEABLE improvement from yesterday, I suggest you bring your FC up to around 20ppm and HOLD IT THERE until your pool clears. I do not think you have killed all the algae.
Are you running the pump 24/7 and cleaning the filter as necessary?
