A full set of test numbers would help. At a guess I suspect that calcium from the cal-hypo is precipitating into a very very fine powder and clouding the water. That happens when you add anything that contains calcium and your calcium saturation index is too high. If that is what happened then adding a little acid to bring the PH down a little generally takes care of it. But there are other possibilities.
