- Apr 5, 2009
- 12
I have a Dolphin 30i that is out of warranty and only works for a couple of minutes at a time. If I turn it upside down outside the pool, it will run and run. If I then put it in the pool, it usually works for a few minutes, then stops. If I put it in manual mode, it works as expected.
I worked with Marina tech support and it looks like it is the motor. I tried to open the motor to see if water was getting into it, but couldn't figure out how to open the motor. I found a couple of posts here with similar problems that were fixed under warranty. I've been underwhelmed with the 30i, so don't want to replace the motor. Does anyone have a suggestion to repair it instead of replacing the motor?
One of the main reasons I don't like the 30i is that I get a lot of leaves in the fall and winter and it instantly clogs if the fabric piece is installed. If I take it off, it works better, but debris falls out when I take it out of the pool. Can anyone recommend a robot that works well for a pool that is surrounded by trees?
Thanks.
Thanks.
