3000 gph intex sand filter and 15x33 pool?
Cheetos82
323
MUSKOGEE, Ok
Intex Krystal Clear
We purchased a 15x33 summer waves that was marked down. Next year we will probably go bigger. I received a free intex sand filter 3000 gph
Is this going to be ok to run on this pool?
Pool is approx 3,157 gallons
We managed to get it hooked up. I just figured out that I can’t use the little vaccum that hooks up to water hose bc we have little water pressure!!ugh more money
no It didn’t. I had bought a cheap skimmer and vaccum kit that you hook up to hose.
I guess what I need is a skimmer plate and vaccum hose but I’ve spent all I can right now
We got the sand filter free 3000 gph intex with pump. Cost us about $30 in supplies from lowes
I had the same problem with my outdoor hose as you. So I had to buy the Deluxe maintenance kit that came with the skimmer plate and vacuum head. It's just an idea, might or might not work but, You could leaving the garden hose attached to the vac head, but removing it from the bib on the house and syphon the water over the side of the pool to vacuum to waste. It wouldn't pick up big things, and you'd have to add more water to the pool after, but if you were really desperate....
I looked up the skimmer plate and it’s crazy expensive. $45 for piece of plastic!
I gotta do something quick it’s already getting dirty. I’ll try out your idea.
