3000 gph intex sand filter and 15x33 pool?
Poolnewbie82
290
MUSKOGEE, Ok
We purchased a 15x33 summer waves that was marked down. Next year we will probably go bigger. I received a free intex sand filter 3000 gph
Is this going to be ok to run on this pool?
Pool is approx 3,157 gallons
Poolnewbie82
290
MUSKOGEE, Ok
no It didn’t. I had bought a cheap skimmer and vaccum kit that you hook up to hose.
I guess what I need is a skimmer plate and vaccum hose but I’ve spent all I can right now
We got the sand filter free 3000 gph intex with pump. Cost us about $30 in supplies from lowes
bloodfromastone
114
Buffalo, NY
I had the same problem with my outdoor hose as you. So I had to buy the Deluxe maintenance kit that came with the skimmer plate and vacuum head. It's just an idea, might or might not work but, You could leaving the garden hose attached to the vac head, but removing it from the bib on the house and syphon the water over the side of the pool to vacuum to waste. It wouldn't pick up big things, and you'd have to add more water to the pool after, but if you were really desperate....
