30,000 gallon vinyl liner pool to remain empty for ~5 weeks?
Apr 12, 2015
50
IL
This is a 20+ year old pool that was installed by the previous owner. I have owned it for 11 years. Bottom of pool looks to be pool-krete while the walls are steel, I believe.
Liner and pool lights are both leaking. I had an electrician who specializes in pools assess the situation yesterday--and he informed me that fixing or replacing the lights would be cost-prohibitive (would require us to break open the concrete to understand how the lighting system was wired up). He suggested there is not a quick fix for the leakage that is occurring from the lights.
At this point in time--I am getting ready to sign a contract with the local Pool company to replace the liner, heater, pump, and pool cover. I am uncertain if we will need to cover the lights or if I can possibly get one of them working. However, bottom line, is the pool will be empty for a while until we can get the installation moving. I expect it won't be until the end of May--at the earliest.
The pool company suggests I completetly drain the pool until then. They told me this will not be an issue--however, this is different than I have learned / been led to believe in the past.
Any advice from the experienced pool owners in this forum?
How badly is your pool leaking?
Keeping water in the pool until the work will be done is a cost for insurance that the pool will not be damaged by ground water or a storm.
If the Pool Company is wrong and your pool gets damaged all they will say is "SORRY'.
The risk depends on your local underground water conditions and the weather. Only you can asses that and if you want to spend on water to protect your pool.
If I filled the pool up above the lights--it is loosing quite a bit of water--probably losing 6 inches a day? Not sure how much damage that is causing either. Pool has been at this level (about 6 inches lower) for the last week.
Keep the water level below the lights then. It is safer then sitting empty.
How deep is the water if you keep it below the lights?
Pour some liquid chlorine in daily so it does not become a swamp. Stir the chlorine in with a brush or put a submersible pump in one end of the pool with a hose to the other end to circulate the water.
+1 I wouldn't feel 100% about it with only the hopper full, but I'd feel much much better at least having the hopper full.
