Hi everyone,
Bought this house 2 years ago, came with a modern in-ground pool that was put in place 3 years ago, everything is basically brand new.
Two first summer were flawless, salt pool system easy peasy to maintain.
This spring (i am in Canada), i'm having trouble with getting enough water sucked into the pump basket from the suction line.
I do not have a floor drain, so main drain/suction is from the skimmer only.
Trying to open the pool last week I saw that I wasn't getting enough water in the pump right, never was the basket full of water.
Of course I did all the basics, fill the drain and all piping with water, nada, always the same.
Basket never full, just air and some flow of water.
I thought the pump was out, went out and bought an Hayward SuperPump. installed it tonight, brand new.
Same thing, pump doesn't receive enough water from the skimmer, it pumps a bit and water... and air.
So I blocked the water entry from main suction line in the pool's skimmer and put the shopvac in it on the pump side.
Guess what, i'm sucking small amount of water... forever ???
Water sucked in is clear as drinkable water, I have no idea what the heck is going on and where it's coming from as the entry is blocked.
Before digging in the ground to check the piping, anything else that I might be missing ?
Thank you!
Thank you!
