Hi All,
This is my first pool, not much experience.
1) I have a valve above the pump that goes to 2 different filters (one small the other is large).
Somewhere in between the valve and the motor, or the valve itself, there is a leak as I clearly see water trickling out constantly.
looks like this:
I lose an inch of water a day from the pool. I did the bucket test and it is not due to evaporation either.
The valve is pretty beaten up, missing some parts, so I think I would want to replace it.
Should I?
If so, what would be the comparable valve I would need to buy?
What glue I need to use to put the pipes together?
I'm also hesitating as the piupe between the motor and the valve has been messed with and not much space to cut the pipes on the 2 sides of the valve either.
2) there are always some air-bubbles in the view-port of the motor, and I don't have enough suction to use the Hayward Pool Vac.
Could the above mentioned leak cause that? if not, what else. I got the Pool Vac recently rebuilt, and as long as I hold it upside down under the water, I can see the legs doing the crawly motion. However as soon as I let it go on the bottom of the pool, it stops moving.
Thank you for any help.
looks like this:
Should I?
