2y Hayward pump not working
Jun 22, 2011
26
Hopkinton, NH
Hi all, I replaced my pump with a VS Hayward 2 years ago, and it stopped working. I installed it, so appears that warranty will not hold?? (Lesson learned)
Electrical panel not lighting and electrical connections appear sound. Replaced the little button battery on the display panel.
Any bright ideas for the sunny weekend??
Can my kids swim as long as the chemistry is just fine? Water is mostly clear- a little cloudiness from the dead algae I’m sure from opening (pump was working for a couple of weeks)
(My pool liner is now 18 years old, so little pattern to see) and we are at peak pollen bloom for the top scum.
Thanks.
If the FC is above minimum and below SLAM level for your CYA and the pH is in the 7's, and you can see the bottom of the pool in the deep end, safe to swim.
Which Hayward pump? Please add the pump to your signature.
