Hi all - finally got to play with my new kit after the fill. Can you please point out if I am heading in the proper direction....
18000 gallon, beadcrete/gunite pool / DE filter - not using SWG yet.
water temp 93 degrees....air temp 104 degrees
DAY 1
CL = 0
PH = 7.8
FC = 0 * can you confirm I do not do this test again until I have at least the minimum CL in the pool.
T/A = 90
CH = 180
CYA = 20
* added 1 gallon of 10% liquid chlorine that evening
DAY 2 (this morning)
CL = 1
PH = 8.2
T/A = 90
CH = 170
CYA = 20
Adding 4.5 cups of muratic acid in next hour
Calculate 5 pints of 10% chlorine to add - should I add once sun goes down?
CYA - should I add any more stabilizer?
BBB - when can I start converting to a BBB method?
DAY 1
CL = 0
PH = 7.8
T/A = 90
CH = 180
CYA = 20
CL = 1
PH = 8.2
T/A = 90
CH = 170
CYA = 20
