I don't have the full system details with me, but a rough estimate of head loss savings and resulting cost savings is the following assuming 50 GPM (easier to look up in the table than 48 GPM) when the solar is on and I'm being VERY conservative (i.e. under-estimating) on the pipe run lengths, not counting elbows, etc.:
To/From Solar: (1.8-0.8) PSI/100 feet @ 150 feet round-trip --> 1.5 PSI
Solar on Roof: (1.8-0.8) PSI/100 feet @ 120 feet --> 1.2 PSI
Combo Line to Returns: (1.8-0.8) PSI/100 feet @ 50 feet --> 0.5 PSI
Suction Lines: (1.7-0.5) PSI/100 feet @ 80 feet --> 1.0 PSI
Return Lines: (0.7-0.2) PSI/100 feet @ 50 feet --> 0.2 PSI
Eyeballs: (2.10-0.66)/2.31 PSI --> 0.6 PSI
TOTAL HEAD LOSS REDUCTION: 5.0 PSI (11.6 feet)
My solar on has 48 GPM, 3000 RPM, 1530 Watts, 24 PSI (pressure-side only, but the gauge may not be accurate) with a calculated head from pump curves of 68.6 feet (29.7 PSI) which would give an implied suction head of around 6 PSI. The skimmer/drain is less than 1 PSI, the pump strainer inlet around 0.3 PSI so with suction piping adds up to 2.3 so clearly there is significant under-estimation not counting elbows, pump strainer basket, true pipe lengths, etc. Nevertheless, let's continue on with the calculation.
If I use the new 29.7-5 = 24.7 PSI, then I get an implied RPM (using the same 48 GPM since that's what the solar system needs) of 2755. That may not sound like much, but it translates into an energy savings of around 270 Watts or a savings of around 18% because the energy formula at fixed GPM has the RPM in two factors either cubed or squared. Remember that the above calculations were very conservative so it's very likely I would have had greater savings -- my best guess would be somewhere in the 300-500 Watts range. Let's use the unrealistic conservative low-end of 300 Watts. The solar is on in my system an average of 5 hours a day (hotter months it's 4 hours, cooler months it's 6 hours) every day for a 7-month swim season and I won't count the the solar off savings for both the swim and off seasons which would be lower. At 40 cents per kilowatt-hour marginal rate this is (300/1000)*5*7*30*0.40 = $126 per season.
Again, this is very conservative and would more likely be closer to $200 per season, plus (assuming the conservative 300 Watts savings) using at least 1.5 KWh/day (45 KWh/month) less energy which is more ecologically conscious. Notice that the 1.5" return/inlet lines are the least problematic since there are 3 or them to split the flow rate and probably would have been kept as is.
Looking at the above, I see that I can get another 0.8 PSI savings above what is shown by going to 3" pipe to/from solar which would have been easy to do for that one to/from dual run (and to the roof). I don't know if I could have stomached 3" pipe for the long return on the roof for another 0.6 PSI savings -- would have been a tough aesthetics decision at that point. If I were to go from 2" to 3" pipe for the to/from solar and the solar return roof portion, I could get over 4 PSI savings from where I am today and wouldn't need to tear up any hardscape, only dig up pipe through a garden walkway. It'll never pay for itself at this point and would have been so much easier to do during installation, but it's something I'll think about, especially if I do any sort of significant upgrade/change to the solar system.
Richard
I agree with you. I don't think people should assume that 2" pipe is going to save them a lot nor should PBs ignore using 2.5" or 3" pipe that might be better for pipes carrying the entire flow rate if runs are long, especially when solar systems are involved. It should also be noted that if one has larger pipe, it does allow for higher flow rates without having costs go through the roof. This may not be normal everyday running, but if someone wanted large flow rates for better skimming during some parts of the day or to do intentional strong aeration with returns pointed up, for example, they could do so without blowing up energy costs. In my system right now, the maximum flow rate is around 80 GPM with solar off and with my IntelliFlo it's at 2500 Watts at that point (interestingly, my older pump could get roughly to the same point at around 2000 Watts so the IntelliFlo is probably not as efficient at high flow rates with high head).bk406 said:I understand it might save you a bit of money. I guess my point is that I really dont like it when the first thing a few people do is jump on someones pool build that has, or is proposing 1.5 inch pipe. For most, its fine. I just have observed time after time that builders and new posters get barrage of "2 inch is better, get 2 inch or find another builder". IMO, such blanket statements are irresponsible, and makes new members nervous about their new pool when the reality is they have nothing to worry about.
Richard
