Sim,
The separate 1.5" lines for each return is fine since you've got so many returns (so the flow is split between them so losses are small). If he did tee them together, then I would have suggested a 2.5" line back to the pump if that was a long run but that's a moot point now. So what about the suction lines? If there are only two (say, one for floor drains and one for skimmers), then that is where I would suggest using 2" lines instead of 1.5" (if there were 3 or more lines, then 1.5" is OK). The last efficiency would be the size of eyeballs (1" vs. 3/4"), but that's not as big a deal since, again, you have so many returns.
Do you know what cartridge filter he is proposing for the system? Do you have a spec sheet for it that shows the head loss vs. flow rate? Since your pool is about 30,000 gallons, I suspect it is a larger and probably oversized filter like mine so the head loss will be low. You won't need to clean the filter very often as a result of its large area and probably won't notice any pressure rise at all when it gets dirty. The manual instructions say to clean when it gets 10-12 PSI above original starting pressure, but I never see it get any noticeable rise over a 7-month swim season (so perhaps 1 PSI or so that I don't notice) yet it does get dirty mostly with suntan lotion (and used to get dirty with cedar needles before we removed the cedar tree).
As for the disagreement, 4JawChuck believes nearly all (95%) of the head loss for the system is in the filter with all filter types and that the remaining loss is almost all in the returns with hardly any loss in piping unless runs are (multiple) hundreds of feet. I disagree, especially with large cartridge filters and write about this later below.
This is not at all the case in my pool where the pump is closest to the shallow end and is still 50 feet away from that end (in a straight shot, which of course the pipe does not take since it goes into the ground and has elbows, valves, etc. at the pad) and 50 feet away from the house (straight shot) for the solar panels. So maybe my PB didn't follow what 4JawChuck is saying and didn't bother to calculate the head losses in the piping in my system, especially for the two 1.5" suction lines, combo (teed) 2" line and to/from 2" lines to the solar recognizing that with the low-head-loss cartridge filter the piping was indeed the dominant source of head loss in my system and he should have upsized accordingly.
4JawChuck,
4JawChuck said:
The DOMINANT flow restriction is used in the design to determine pump capacity and power required to move the fluid through that restriction while maintaining the required flow rate.
In general plumbing designs are based on experimental data such as head loss graphs etc. for the various pieces of the design, however this design data is used to determine DOMINANT flow restrictions to ensure the design is optimal for the pump nomenclature. They are not to be used in an additive formula to determine theoretical flow rate gains such as has been proposed, this has to be determined through experimentation and actual field tests. I can tell you from experience, the scenario presented is not probable or possible due to the design of the common pool plumbing system.
You don't use the head losses in the calculation since it is not the DOMINANT flow restriction...OK? I know it can be confusing because you will not find anywhere on the internet where it tells you this in plain language, it is assumed as common language/knowledge because thats how hydraulic engineering is taught.
I disagree. If you look at virtually any documentation for how to determine Total Dyanmic Head, it includes the piping as well as the equipment (i.e. filter) and does not simplify to assume certain dominant loss. For example, see
this file from Hayward which says:
For new installations, it is possible to calculate TDH very accurately by using
reference tables and manufacturer’s data to determine the friction loss asso-
ciated with every component in the circulation system.
or
this link and
this link and
this link and
this link all of which include all components ADDED TOGETHER in calculating Total Dynamic Head (see where it sums main drain line loss, skimmer/gutter line loss, return line loss, filter loss when dirty, heater loss, other).
This link is similar in summing up piping, filter, heater and other losses. You don't just take the largest one, especially when one isn't hugely above all the others combined.
This link doesn't even include the filter in the TDH calculation and I would agree with you that this is wrong, especially if a sand filter is used.
This link says the following about calculating TDH:
The working capacity of the pump is based on the design of the pump and the calculated total dynamic head of the system. The following information for determining total dynamic head must be included in plan submittals for VGBA compliance:
Total dynamic head (TDH) is determined with:
A. The pump curve
B. The elevation difference between the pump and the basin’s water elevation
C. Friction loss through permanently-affixed fittings and pipe
Permanently-affixed includes inlet eyeball fittings that are anchored to the pool, but not those that are removable without tools. Permanently-affixed also includes weir plates or other immovable flow restrictors.
D. Friction loss through any clean filtration devices or heating equipment.
Though the above refers to friction from fittings and pipe, filters and heaters, it is incorrect with regard to elevation between the pump and the basin water level since that is static head to overcome when priming, but once primed any loss on the suction side is gained on the pressure side so cancels out (and isn't part of dynamic head).
As I showed above, an oversized cartridge filter has very low loss (and doesn't get a large rise in pressure under normal conditions either) so cannot be assumed to be dominant even with pipe runs of 50 feet. I have given a similar example (with somewhat longer pipe runs) before yet you have not explained why you believe the filter is still the dominant factor. For 50 feet:
Jandy CL-340 Cartridge Filter @ 90 GPM: 5 feet of head (2.2 PSI)
50 feet of piping:
1.5" at 45 GPM: 50*(11.7/100) = 5.9 feet of head (2.5 PSI) such as with two 1.5" suction lines
-OR-
2" at 90 GPM: 50*(12.4/100) = 6.2 feet of head (2.7 PSI) such as with one 2" teed line or to/from solar (so 25' each way), etc.
Please explain to me how the cartridge filter with 2.2 PSI is the dominant source of head loss in this system with only 50 feet of piping (not 100-300 feet) with 2.5-2.7 PSI for piping alone? Yes, the filter is assumed to be clean, but as my own experience and the experiences of others with large cartridge filters shows, they effectively do not rise in pressure before getting cleaned once or twice a year.
4JawChuck said:
To be honest I think the real discussion should be how often should I clean my filter to save energy (less pumping losses) and should I use a filter thats three times larger than recommended since that is the dominant restriction in the plumbing and pumps run for long periods with a dirty filter...thats where you should spend your money since it would represent the largest return on investment in daily use.
I completely agree with this. For energy efficiency and less frequent cleaning, one should definitely get an oversized filter and do not let the pressure rise very much before cleaning. For sand filters, they tend to clean better when a little dirty, but even so one shouldn't wait until the pressure rises so much that it significantly affects total head loss and therefore energy costs. For an oversized cartridge filter, one may see very little rise in pressure even when dirty (this is the case with my filter). I assumed that with Sim's 30,000 gallon pool that the cartridge filter would be large and likely have a very low head loss similar to my 340 square foot (4-cart) cartridge filter, hence the losses in piping could not automatically be ignored.
Richard
