Just closed on a house with a in ground 15K pool and hot tub. A little history on the pool. The house has been empty for 8 months, no one has been in the pool and the owner used a pool company to maintain the pool who only kept the chemicals in line, did not clean or anything else. The pool is about 25 years old and is gunite with the original finish. A pool inspector told me all the equipment was in good order and that the pool was going to need a new surface in the next couple of years. Yesterday I tested the FC and PH with my trouble free test kit. the FC was 15 and ph was 7.1. the pool was clear. Well I got in the pool and noticed a white substance coming off the wall when I touched it causing the pool to get cloudy. Fast forward to today. I did a complete run down on the pool with the following results.
FC-14
ph-7.1
TA-80
CH-500
CYA-50
Well I added some soda ash to bring the PH up, I hit 7.5 later on in the day but the pool became very cloudy. So I took the cartridge filter apart and it was pretty dirty so I washed it up and continued running the pump. Then went to scrubbing the sides of the pool to get the white powdery substance off. (Which I believe is calcium). Now the pool is a complete mess, its very very cloudy and does not seem to be clearing up. Just wondering with that high of a calcium level is it going to clear? What am I going to have to do to bring the level down? I have read that I may need to drain part of the pool, but I am clueless on how to even go about doing that. I left the pump running tonight in hopes it might help, but I guess I will see in the morning as I have no moved in yet.
Thanks for any info, just wanting a clear pool to enjoy this last part of summer. Sorry for such a long first post.
FC-14
ph-7.1
TA-80
CH-500
CYA-50
