- Jun 30, 2010
- 6
Hi everyone We have soft-sided above-ground Splash pool. The foundation is fine sand on solid ground, with a plastic sheet between the pool and the sand. The legs are resting on plywood strips on the sand to help keep them from sinking in. The whole foundation is surrounded with wood.
Im wondering about covering everything with pea gravel around the pool, to help keep the kids from tracking sand into the pool, and to give the foundation a nicer appearance. Should I be concerned about any wear and tear from the pea gravel resting against the sides of the pool? The pool doesnt move so its not as if the pool material would be rubbing back and forth on any hard gravel.
Other suggestions welcome, if pea gravel isn't the best choice. Thanks!
(in these photos, the pool is only half full, so the sides are leaning a bit... its full now
