G
Guest
Bruce is on an extended vacation till next week, not sure if he is going to chime in until then!
salp said:Does "Sunken Treasure" limit how much CYA it dumps in the water?
Well, yes and no. If the pump is running and the circulation is good, then there won't be any appreciable difference. On the other hand, if the pump hasn't been running for several hours, or the circulation is especially terrible, then the chlorine will be more concentrated near the dispenser and more chlorine will be lost near the surface than from the deep water. But even then, the difference shouldn't be anywhere near as large as what Safe&SavePoolChemist claims.ride525 said:Does the chlorine on the surface burn up quickly like safensavepoolchemist.com says? Does much of it get released to the atmosphere?
That doesn't make even a tiny amount of sense. First off, you don't have to regularly use shock regardless of how you add chlorine, at least if you know what you are doing. The need to shock comes from a failure to maintain proper chlorine levels. I suppose you could argue that the Sunken Treasure popping to the surface serves as a reminder to add chlorine, but given home owner behavior I've seen I wouldn't expect that to make much difference.Safe&SavePoolChemist said:That's why you have to regularly use shock.
From BBB Method for Beginners, here in Trouble Free Pool:Shane1 said:Safe&Save how do you recomend pool owners regulate CYA levels?
CYA can be increased by adding cyanuric acid, often sold as stabilizer or conditioner. CYA is just about the only chemical you need to go to a pool store to get. Check the label to be sure you are getting cyanuric acid since there are other products that use the words stabilizer and conditioner in their names. To lower CYA you must replace water, or if replacement water is extrememly expensive use a reverse osmosis water treatment.
ride525 said:From BBB Method for Beginners, here in Trouble Free Pool:Shane1 said:Safe&Save how do you recomend pool owners regulate CYA levels?
I don't know if there are any other ways.
Jeff
Shane1 said:simicrintz: I was really hoping to see those plaster damage pics.
Honestly? You would rather spend $55 on these ridiculous gizmos than on a proven device such as this inline chlorinator?creativone said:After seeing these treasure things I am going to take my next extra $55 (usa) of pool funds and get 2 for my diving pool. It will save me that much in chlorine in a short time.
Who goes to the store every 3 days for chlorine? :lol: If you are using that much save yourself some trouble and get a SWG, it will pay for itself.creativone said:Liquid chorine is not a good option for us because there is no safe place to store it the garage is too hot, the so it the patio. and who wants to go to the store every 3 days for chlorine anyway.
Hey Bruce, I'm with you man! I would never recommend pucks as the sole means of chlorination over bleach or SWG. I was just trying to follow the logic behind these guys arguing for floater or "sinker" technology. They are admitted puckheads, if I may coin the term, but if they are insistent on using pucks why use inferior products when there are better solutions available. That's all I was trying to say...simicrintz said:Beez-That inline chlorinator is as bad as the "sinker"! That is a unit designed for pucks, no different than the floaters, and awesome at dispensing way too much CYA as time goes on. Don't refer these to people to buy, when I have several laying around that I have pulled out of pools after people learned about BBB! I'll give 'em away!
Beez said:Hey Bruce, I'm with you man! I would never recommend pucks as the sole means of chlorination over bleach or SWG. I was just trying to follow the logic behind these guys arguing for floater or "sinker" technology. They are admitted puckheads, if I may coin the term, but if they are insistent on using pucks why use inferior products when there are better solutions available. That's all I was trying to say...simicrintz said:Beez-That inline chlorinator is as bad as the "sinker"! That is a unit designed for pucks, no different than the floaters, and awesome at dispensing way too much CYA as time goes on. Don't refer these to people to buy, when I have several laying around that I have pulled out of pools after people learned about BBB! I'll give 'em away!
