Trying to get some data to see if we can figure out what contributes to the formation of White Stuff.
1. How long have you been using the LQ?
2. List your equipment.
4. If so does it affect the performance of your LQ?
5. How often do you have to clean it out?
6. What parts of the unit are affected by the WS?
9. What size LQ do you have? (4 gal or 8 gal)
10. Do you have a device that aerates the water on a regular basis? (fountain, water fall, etc.)
11. A full set of test results?
12. Anything else you feel is pertinant to the situation.
- Pump?[/*:m:1k0299su]
- Filter?[/*:m:1k0299su]
- Norm filter press?[/*:m:1k0299su]
- Number of skimmers?[/*:m:1k0299su]
- Number of returns?[/*:m:1k0299su]
- “In†float valve?[/*:m:1k0299su]
- “Out†float valve?[/*:m:1k0299su]
- Flow meter?[/*:m:1k0299su]
- Flow control valve?[/*:m:1k0299su]
- “In check valve?[/*:m:1k0299su]
- “Out check valve?[/*:m:1k0299su]
- “In†tubing?[/*:m:1k0299su]
- “Out†tubing?[/*:m:1k0299su]
- “In†side only?[/*:m:1k0299su]
- “Out†side only?[/*:m:1k0299su]
- Both “In†& “Out†sides?[/*:m:1k0299su]
- Part of “In†side?[/*:m:1k0299su]
- Which parts?[/*:m:1k0299su]
- Part of “Out†side?[/*:m:1k0299su]
- pH[/*:m:1k0299su]
- FC[/*:m:1k0299su]
- CC[/*:m:1k0299su]
- TA[/*:m:1k0299su]
- CH[/*:m:1k0299su]
- CYA[/*:m:1k0299su]
- Salt[/*:m:1k0299su]
- Borates[/*:m:1k0299su]
