Thread: Changing coping clips without emptying pool, help?
    My pool has an overlap-type liner, and holding it on are the standard white plastic coping clips. But, over top of the clips, there are another set of metal clips. My problem is that these metal clips are poorly galvanized and are disintegrating due to rust on the inside. So lots of rust is falling into the pool . What Im wondering is whether these metal strips can be removed and replaced without draining the pool. To me, it looks like the purpose of these strips is to provide structure, not hold the liner in place. Would removing just one section at a time (4ft) compromise the strength of the pool and cause either the liner to slip or the side to collapse, under the weight of all those 13000 gallons? (24ft circle pool) thanks dudes!
    ps- this forum has awesome smileys -->
    Re: Changing coping clips without emptying pool, help?
    bumps... anyone got any advice?
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    How long is each section? It may be possible - the round pools are supported by pressing outward equally on all sides/walls. One of the pro installer dudes will be along to help but my guess is MAYBE
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Assuming your pool walls are metal, you should have no problem as long as you remove and replace the metal strip one section at a time. This will not cause the walls to collapse.
    33000 IG vinyl pool
