I read that you can add salt to your CH pool to get some of the salt water feel, How much do i need to add to my pool, Once it's cleaned ? "Salt can simply be dumped into the pool. Spread it around a bit with a brush so there aren't any large piles, and leave the pump running for 24 hours after adding salt. If you have a SWG, it should be turned off while you are adding salt and for the next 24 hours"
