- Jul 21, 2008
- 45
joykens said:Fatheroffive, you need to keep your FC at shock level until your pool passes an overnight loss test.
Okay we will try that tonight.
Added about 4 gallons of 6%
FC 23
CC .5
I will check again in the morning.
Bama Rambler said:How long after adding the 4 gallons of bleach did you wait to test?
What was your CC level this morning?
If your CC was .5 or less and you're sure you lost only .5 FC then you're technically done shocking. However, I'd recommend you maintain shock level one more day just to be sure. You've been at it this long, no use getting antsy and ending early.
I know, Patience is needed. Last year everything on here worked perfect and the pool looked much worse when opening. We had it clear in about a week. This year is different. The pool is clean, FC is holding and my numbers look better then last year and its still cloudy. So far used much more bleach this year then last. Got a birthday party closing in on us sat and its gotta be ready or they will just swim in cloudy water. :grrrr:cheddar85 said:I know you're really frustrated with how long it's taking for the pool to clear up, but the methods here WILL work! There isn't a magic cure at the pool store, the only thing I recommend is a big bottle of POP (pool owner patience)! Once all the organics in the pool are killed, it just takes time to filter everything out. You're so close, just keep doing what you're doing and listening to the great advice here, and you will get there!
BTW, the 'shock' you added may show up CC's on your next test, depending on how long before you test again. Just thought I'd give you a heads up!
fatheroffive said:Still milky.......This is driving me crazy. How can I tell if my sand filter is channeling? Or should I give it more time to clear out the Algea I scrubbed out from under the steps yesterday?
Butterfly said:If your water does not show improvement each day, you may want to clean your filter.
Butterfly said:fatheroffive said:Still milky.......This is driving me crazy. How can I tell if my sand filter is channeling? Or should I give it more time to clear out the Algea I scrubbed out from under the steps yesterday?
I'd definitely check the filter.
