Results 1 to 8 of 8
Thread: Spa Jet Blower problem
    Nov 2007
    Rockland County, NY
    65
    Hi All,
    We have a 20 X 40 IG with attatched spa. The spa has eight jets. When I run the blower 2 or 3 of the jets deliver very little air. I am assuming (probably incorrectly), that the water column in those lines is preventing the air from being pushed through. The blower is 2 hp. What is the remedy? Can I safely attach my air compressor to clear out the lines? Any help would be greatly appreciated. Thanks.
    Rob
    27ft Above Ground Pool
    Sand filter
    South Central NJ
    3,192
    Re: Spa Jet Blower problem
    Can you post a pic of the jets?
    Scott
    Owner of - PoolGuyNJ LLC
    Nov 2007
    Rockland County, NY
    65
    Sure...probably can't get to it until tonight....just a standard spa jet though.
    Sand filter
    South Central NJ
    3,192
    There are 100's, if not 1000's of different ones.
    Scott
    Nov 2007
    Rockland County, NY
    65
    Quote Originally Posted by PoolGuyNJ
    Scott
    Huh...Ya live and you learn.
    Either way I'm not sure the problem is jet related. One has a single hole that doesn't move, the other has two holes and spins around. You can adjust flow by turning either CW or CCW..but the problem is there even if the jets themselves are unscrewed from the spa wall.
    Rob
    Sand filter
    South Central NJ
    3,192
    Your symptoms lead me to believe the air holes have debris clogging them. Do you know what jets and bodies were installed?
    Scott
    Nov 2007
    Rockland County, NY
    65
    I will try to unscrew the jets in question and have a photo for you tonight. Thanks for the help.
    Rob
    Sand filter
    Feb 2010
    Houston, TX
    271
    I agree with PoolGuyNJ, sounds like an obstruction. There's not much to the air system - blower, lines, and jets. The blower works fine, so that would pretty much mean an obstruction somewhere.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
