Results 1 to 12 of 12
Thread: New pool, new test results
    Jul 2007
    Inman, SC
    17
    I'm just getting started with my new pool, since it was just filled. Have so far just added some bleach, baking soda, and stabilzer last night and vacuumed real good. Pump run all night and this is my test results this morning. What do you think? Am I on the right track? Also, I have a cartridge filter and am unsure about how and how often to clean it; and how long to run it everyday! Any tips would be appreciated. Here's my numbers.
    CL 5.0
    Ph 7.6
    Alk 70
    Br 11
    Hardness 100
    Stabilizer 30
    16X32X4.5 rectangular, vinyl, inground
    pleasekeepmypoolclean
    Houston, Texas, USA
    148
    Re: New pool, new test results
    Quote Originally Posted by pleasekeepmypoolclean
    CL 5.0
    Ph 7.6
    Alk 70
    Br 11
    Hardness 100
    Stabilizer 30
    Looks real good. Did you check for combined chlorine (CC)? Don't worry about bromine since you are using chlorine (I assume you are using a DPD test that checks both simultaneously). How does the water look?
    I can't help on the cartridge filter questions, I'm a sand man. It may take some time to determine how long you need to filter each day to keep the water clean and clear. I would start by running it 8 hrs a day.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Typical pump run times are between eight and twelve hours a day, though some setups require more or less than that. I would try 10 hours a day and if after a week the water still looks great then lower the run time a little and if instead it gets worse then raise the run time a little.
    Your numbers look good. CYA (stabalizer) can take up to a week to disolve, so CYA will come up some more over the next several days. Also, Br normally stands for bromine. Since you are using chlorine instead of bromine as a sanitizer the bromine reading isn't useful (it is just detecting the chlorine).
    Take a look at the pressure gague on the filter and note the current reading. When it reads 8 to 10 psi higher than that clean the cartridge (at least once a year in any case). A quick cleaning can be done by simply spraying the cartridge with a garden hose. A more complete cleaning involves spraying the cartridge off as normal, then soaking the cartridge overnight in one cup of automatic dishwasher detergent (not dish soap) and lots of water (enough water to cover the cartridge) and then spraying it off with a garden hose again. Many people like to have two cartridges so a clean one can be put right in while you clean the dirty one for next time.
    Jul 2007
    Inman, SC
    17
    Thanks. No CC and the water is sparkling clear this morning. What do you suggest I keep the chlorine level at consitently and what would be "shock" level? Oh, my new system doesn't have a pressure guage as my previously owned sand filter did, so that's one reason I was unsure of when to clean it.
    Houston, Texas, USA
    148
    Maintaining a free chlorine of 11.5% of the cya should keep green algae away. As far as shock level, it depends on what you are shocking for. Green algae shock to 40% of the cya level, yellow algae shock to 60% of the cya level. For CC, shock to 10x the CC (for example if you had 4.0 free chlorine and 1.0 CC, add 10 ppm free chlorine to the existing free chlorine, for a total of 14.0 free chlorine). Your filter should have a 1/4" pipe thread for a gauge somewhere. Maybe it's plugged with a pipe plug?
    Poor Man's Pool
    50 ppm borates
    For CYA between 30 and 50 maintain FC at or above 3 at all times, perhaps add to 6 or 7 so it is still above 3 later, and shock to 15. Check in a week to be sure your CYA level didn't go above 50.
    Without a gague it can be a little tricky. Does it have a place where you can add a gauge? If the water looks dull or cloudy and there isn't any other explanation, such as too low a FC level, then clean the filter. Over time you will get a sense of how frequently you need to clean the filter in various seasons.
    Jul 2007
    Inman, SC
    17
    Cartridge filters are not equipped to backwash like sand filters. You just remove the cartridge and hose it off. I do think it may have a place for a guage, though. I'll check into that. Thanks for your help!
    I guess you can tell what kind of filter I don't have even without my sig The concept is the same though.
    Jul 2007
    Inman, SC
    17
    You are absolutely right. The concept is the same. I had a sand filter on a previous AG pool. This one just operates a little differently. Thanks!
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Without a pressure gauge, about all you can do is check your return flow back to the pool. With a clean filter, you should get a good strong flow out of the return, and as the filter gets dirtier and dirtier, the flow will be reduced. I've got a cartridge filter as well and mine has a gauge that I've had to change twice already, so I pretty much just check my return flow along with a cursory check of the gauge.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Guest
    Cartridge filters SHOULD have a pressure gauge since an 8 psi rise in pressure is when you are supposed to clean the cart.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    OK, I stand corrected. Get a gauge installed.
    Intex 8110 SWCG
    "Fear the Schnauz!"
