Is it ok to switch between high to low, or low to high without turning the pump off first? My last pump had a rocker switch with low/off/high position. The new pump came without a switch so I had to order one for this specific pump. It is a toggle switch with just low/high position. Do I need to turn it off with the power switch located on my pad before switching speeds? Thanks!!
