2 Speed Hayward Pump Trips GFCI when on high
robbyv17
7
Chicagoland
I have a dual speed (2HP & 0.25HP) Hayward pump that has been in operation since 2016, according to the previous owners. It ran fine without a single issue the last few years for me. I opened the pool recently, and when I attempted to use the high speed, the GFCI outlet (under the deck, not the breaker in the panel) tripped and couldn't be reset. I replaced the GFCI with a new 20A weather resistant GFCI.
The pump runs fine on low again, but switching to the high speed trips the new GFCI as well ( am able to reset the new GFCI, unlike the old one). The other test I've done is running the pump on low and plugging a hairdryer in that GFCI outlet to stress test it and it did not trip.
Signs point towards the pump being the issue. Is there anything else that I can try before shelling out for a new pump?
And if I do need a new pump, are there any recommendations for dual speed pumps? Thanks!
Update: I found the following video and it worked for me. I just had to pop off the back cover of the motor and use a screwdriver to manually rotate the impeller shaft a bit. Hopefully it buys me an extra few seasons out of the pump.
Sounds like there is a short in the high-speed windings. Can you post a picture of the pump? This one:
Same pump, different label. Problem with those pumps is you can replace the entire pump for slightly more than the cost of that motor along with the O rings, shaft seal, any gasket needed to make the repair. Plus your labor.
PowerFlo Matrix pumps, in a 2hp, 2-speed configuration, are about $550.00. That motor Century BN61) alone is about $375-$530 depending on availability (online pricing). A GO Kit with the shaft seal and O rings, etc., is about $35.00.
The rust at the top of the motor, unless you know water has been dripping there, is an indication of a motor that has been overheating.
My local pool store has a new pump for $470, so you're right, it doesn't make much sense to get a new motor + GO kit. Thanks
Reactions: 1poolman1
