I'm a new pool owner and just started testing with the HTH 6-way kit I picked up at Walmart. I know the TF-100 is the ideal test, and I plan to get, however, I just need to give my pocketbook a little rest. This install has cost me so much more than expected. Anyways, here are my results:
Any feedback is much appreciated - I just need to get thru the next couple of weeks until I can afford to get the TF-100 test.
- The size of my pool (15x48 Intex) says 4400 gallons on the box, however, PoolMath calculates 5300 gallons. Which one should I use?
- I dropped these numbers in PoolMath using 4400 and got some instructions, however, where does TC+Bromine go? Also, there is no option for TH.
PH 7.3 > add 11oz of borax -- this says PH depends on TA and Borate. I don't have a test for Borate so I'm not sure what to do. Since my TA is high, does the PH need to go down?
TC + Bromine 2 > ??
CYA 10 > add 18oz of stabilizer -- I plan to use the sock method
TA 120 > looks like lowering the PH will take care of this??
TH 140 > ??
TC + Bromine 2 > ??
TH 140 > ??
