@HermanTX @TampaKathy @duckcmmndr
So my project manager and one of the supervisors and more seasoned Project managers came out with the transit level today.
They checked the skimmer levels and there is a about 1.25” difference as of now from the outside. It originally shows close to 2” but then they had to readjust cause they didn’t start from same spot because it had mud and Gunite in the spot.
It rained a ton so they weren’t able to get in the pool so they are going to come back with the Gunite company next week since it’s raining this whole week.
They will pump out the water and set the transit and check the bottoms of the skimmers in there to get an exact level and see their options.
They said either the skimmer was leaned down and not level when they shot which makes it off or it’s completely not level. Either way as of now doing the level from the ground using a tape measure it was off.
I asked what would happen if it that shows that it’s not level again. The older guy said the Gunite company would have to crack out the skimmer and adjust it properly and fix it up.
I asked if that would mess with the integrity of the shell and he said no. Saying that the beauty of Gunite is there are no cold bonds. AndI they can build on top of it just fine.
Is that correct? Do I have anything to worry about if they have to do that fix?
The main project manager didn’t like hearing it was off after he kept pressing and say he knows for a fact they are level and probably thought I was crazy.
