HI everyone,
I just had my pool installed and because of weather couldn't get the water truck so, I started with my well, then don't laugh used my sump pump to fill the pool, in the spring my pump goes off every 20 seconds or so, any way I did a few of the tests and some numbers are way to high I think. 1st does the temp matter water is below 70 degrees. I stopped testing when I saw these numbers. does it look like I have to drain some or could the temp cause some of this.
TA- 470
CH- 475
FC- 5
PH- 7.5
CYA- 0
Thanks
TA- 470
CH- 475
FC- 5
PH- 7.5
CYA- 0
Thanks
