Thread: Is Pool Tile Really Needed?
    Hey Forum,
    I am in the process of cleaning up/opening up my pool, and I wanted to know if I Really need pool tile. I personally think it is a the biggest waste of money ever.
    Is their any real logic for pool tile, outside of the look?
    Pool Size - Trying to figure that out. SBMW 2000 (2048 Model) Inground Pool.
    Re: Is Pool Tile Really Needed?
    The logic to pool tile is that the waterline has a huge amount of grease, scum, and oil that collects on the tile.
    The tile is easily cleanable, and the plaster is not.
    Without the tile this gunk would stick to the plaster and stain it- literally this stain would not be cleanable
    Unless you are William Randolph Hearst (loaded with dough)- you just tile the waterline.
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Guest
    What Dave said, and the fact that pool plaster needs to remain wet; it does not like to be exposed to air and will fail.
    THanks fellas, no one has every explained pool tile in that fashion
