Hello again,
I need some clarification here,(pardon the pun). I'm still confused about the metal problem I seem to have. I understand that the chlorine is reacting with the metals in the water. If I am right in saying this... the chlorine reacts with the metal and turns it green, kind of like a test strip does when introduced to the pool water right? The chemicals that are put on the strip cause the color change to indicate what the ppm or level of the chemicals that are in the pool water, is this correct? I'm trying to put this in laymen's terms to "KISS"(keep it simple stupid). Oh btw I am using a 6 way test kit not the strips even though I have them. I will be ordering my new kit soon but I want to use up what I have for now.
SO... where I am getting lost is here....My FC is between 3-5 when tested in the am, and the water has its normal green tint. I haven't added any bleach within the past 24 hours. I used "HTH metal control" this time to see if I would get a different result and also it is easy to get and cost $11 vs $17 from the pool store they sell "Regal" brand. Not sure if they have the same compounds or not. The pool store brand is call "metal out". I'm thinking just a different wording. The HTH brand active ingredient is "Hydroxyethylidene Diphosphonic Acid" (however you say that).
Ok back to "KISS"! So 2 or 3 hours later I have beautiful blue water or should I say a beautiful blue liner. LOL The water is crystal clear. I do a test to see what my FC is and it is at 1. This is where I get frustrated/confused. What it seems to me that is going on here is the "Metal Control" is just removing what is causing the water to turn green in the first place,the chlorine reacting with the metals! I know you have to have chlorine but I don't want the metals. Living in the south I worry that I will get algae very easy due to the amount of rain we get and the warm temps. I would feel more comfortable with a FC around 3 just to be safe if needed. Am I wrong here? Will a FC level of 1 be ok as long as all other levels are ok?
I waited 36 hours and kept a close eye on the FC level which was at 1 or less. So as a test I added a quart of bleach. With in 30 min it was back to its mean green self, which is wild to watch 19k gallons go from blue to green from only 32 oz! Normally to maintain my FC level I use the "Pool Cal" to double check how much to add even though I think I have a handle on how much to add compared to levels from test. This time I added less just to see if it would bring up my FC a little and if the water would turn green again. Of course it did. FC level didn't change much, maybe a solid 1.
Sorry so long just to get to these questions but I just wanted to explain what actually is taking place with a time line. Like I said I believe I do understand what is happening, but what I see is by adding the metal remover (so its called) isn't removing any metal. Its stopping the reaction by removing/reducing the chlorine right?
1. Is there a permeant solution for this? I understand when new water is added more metals will be added. I try not to let the water level get to low so less water will be added.
2. Could anything else in the water/levels cause this same type of reaction? Isn't alkaline a metal? If so, would a high alkalinity level cause the same problem? I noticed when I add the sequestrant (i.e. metal out) my ph drops and as pool school points out (yes I read it, LOL
) lowering the ph lowers the alkalinity. My PH has been a little high along with my alkalinity. I also noticed when I add the bleach the PH goes up. My PH hovers around 7.5 but sometimes closer to 7.8 with my alkalinity around 110. It used to be much higher but I added the required amount of Muriatic (hope I spelled that right) acid but no change to the color of the water.
3. Can having 0 CH have any effect on the metals or reaction on the metals that may cause some of my problems? We never added any calcium chloride (even though the pool cal said it was required) because I didn't think it had that big of an effect on a vinyl pool. But what do I know! :?
4. Could there be something with the liner or filter etc... that is causing this same reaction? New pool installed about 2 months ago. Only reason I ask is because we had an 24' Intex temporary pool in the same place as our new pool but never had a green tint problem except when the wife forgot to add chlorine and we had a algae break out. She would just add a bunch of Shock and Swim (we were clueless back then) but still no green tint/metal problems. Now I do all the balancing :lol: , Thank you TFP!!!!! I now enjoy taking care of our pool! Now if I could solve this problem all would be right. I guess what's bugging me the most is, I have to be missing something! I would have thought with the large amounts of chlorine my wife used to throw in our old pool that we would have experienced the same problem. Is there anything in standard store bought chlorine etc.. that might have something in it that I may be missing using the BBB method? According to the pool cal and testing we really only require the bleach out of the BBB method unless I'm missing something.
This site has helped us so much. We have come such a long way in a very short time. If you would have asked me a few months ago what my FC or PH, or CYA etc was I would have been lost! What I have learned from TFP can be summed in these words.......
"LESS IS MORE WITHOUT ALL THE CHORES, SO FOLLOW TFP AND IN THE END, THE POOL OWNER SCORES"!
Thanks again for the help,
Tim
I may not be an expert when it comes to a pool, but I have been an appliance tech for over 27 years so if you have a question feel free to ask/PM me.
