Got my test kit and tested the water (forgot to do pH) but the water wasn't circulating so I don't trust the accuracy to be great. Going to do it again in the morning after letting the pumps run overnight.
On the CH test, when the water turns blue is it like BAM ITS BLUE!!! or is it like a very delicate almost perfectly clear blue? I saw a very slight tinge of blue at something like 30 drops, and it went less blue as I continued adding. I added 220 drops... i sure hope my calcium isn't above 2200
My inaccurate test results:
FC 6
CC 0
TA turned pink at 120 then cleared up shortly after, stayed pink at 130
CYA 50
I doubt the inaccuracy due to not cycling the water is massive, so it's looking good for my CYA.
Edit: It was the CH test that I messed up and used too many drops, not TA like I initially wrote. I've corrected my mistake.
FC 6
CC 0
CYA 50
