Thread: Start up question
    Start up question
    We will finally be getting our pool pebbled at the end of this week or next. My PBer will be starting up the pool. As I read the start up procedure in the pool school it said to wait to add salt for three weeks. Our PBer says that adding salt wont be a problem with Pebble. He said that the information given in the pool school is for regular plaster not pebble. True or False?
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Re: Start up question
    In my understanding, pebble IS regular plaster with the aggregate in it, which is acid washed to expose the aggregate. I may be wrong.
    So you treat an aggregate surface (from a chemical standpoint) the same as plaster.
    Just be sure whatever you do (or don't do) will not void your warranty.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Plaster is the same as pebble salt wise, except that there is less plaster. Most of the surface is pebble, with only small strips of plaster between pebbles. Those small strips of plaster need to same care as a plain plaster surface would.
    Not everyone agrees about the need to wait before adding salt. The National Plasterers Council says not to add salt for 28 days, but many builders add it anyway and nothing too obvious goes wrong. In theory, salt will cause pitting of the plaster surface, which isn't such a big deal between the pebbles where it will be difficult to see, but it does weaken the surface a little.
    Vero Beach, FL
    462
    The warranty on my product states that all NPC and the Association of Pool and Spa Professionals guidelines must be followed. If it were me, I'd either get the PB to leave the salt by the pool and add it myself after 28 days, or write a note on the contract about him adding the salt early against NPC guidelines and get him to initial and date it. Well, actually I would not let him do it early period.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Spoke to him and Ill add the salt. Should I treat with bleach till then?
    Bleach is fine. You could also use trichlor tablets. Trichlor adds chlorine & CYA and also lowers the PH, all of which you want when you have fresh plaster.
