- Feb 5, 2025
- 93
- Vinyl
- CircuPool RJ-45
Plumbing breakdown, may be an extra fitting here and there not accounted for. I know allot of the stuff I'm posting on this thread is a bit redundant but I want to put as much on here to hopefully help someone else out in the future!
Pool Plumbing, ALL 2” SCH-40 PVC or CVPC
INYO = INYOpools.com
PW = Pool Warehouse
LOWES= Lowes Deptford/Mantua found online in stock
Pool with 2 returns, 2 skimmers, 1 water feature, pump and filter assembly
-Total with double union ball valves excluding tax and shipping = $906.03
Total with single union ball valves excluding tax and shipping = $685.93
Total cost for heater bypass excluding tax and shipping = $234.14
PW = Pool Warehouse
- (3) – 3-Way Valves $133.80 / $66.90 INYO
- CMP Pool and Spa 3-Way Diverter Valve, 2" Inside, 2-1/2" Outside, 25913-204-000
- (2) –2-Way Valves $129.02 / $64.51ea INYO
- CMP 2 Way Diverter Valve, 2" Inside, 2.5" Outside - 25912-204-000
- (5) – Union Ball Valves
- Double Union $290.00 / $58.00 each PW
- Astral 6622 True Union Ball Valve, 2 In. Socket, 2-Way, PVC
- Fully removable and rebuildable
- (5) - Single Union $69.90 / $13.98 each LOWES
- RELIABILT 2-in PVC Single union Sch 40 Ball Valve Item #209668
- $220.10 cheaper than double union valves but not rebuildable
- (2) – Unions
- Slip-Slip Union $44.44 / $22.22 each LOWES
- (2) – Tee’s
- Slip Tee $9.90 / $4.95 each LOWES
- (21) - 90⁰ elbow
- Slip 90˚ elbow $96.18 / $4.58 each LOWES
- Charlotte Pipe 2-in 90-Degree Schedule 40 PVC pool sweep Elbow Item #23910
- (9) – Couplers
- Slip coupler $19.62 / $2.18 each LOWES
- (4) - Reducing Male Adapter
- 1-1/2” MPT – to – 2” slip reducer $20.88 / $5.22 each LOWES
- Charlotte Pipe 2-in x 1-1/2-in Schedule 40 PVC Reducing Male Adapter Item #137434
- (20) – 10’ sch40 PVC pipe
- $273.60 $13.68 each LOWES
- Charlotte Pipe 2-in x 10-ft 280 Psi Schedule 40 PVC Pipe Item #23832
- (1) - CPVC Orange Lava Hot Cut-In Cement (16 oz.) $20 each LOWES or Home Depot
- ALL 2” PIPE AND FITTINGS
- (2) – 2-Way Valves $129.02 / $64.51ea INYO
- (1) – Check Valve $50.78 INYO
- CMP Check Valve, 2" Inside 2-1/2" Outside, 1/2 lb. Spring - 25830-814-000
- (2) – Tee’s
- (2) Unions
