Just joined here. Looking for some help/suggestions.
Found this site while searching around the PoolFurum.com (I guess you can't join over there anymore.)
I've got an 18' round AG (About 16 years old) in Ma.
Over the winter something let go and all water dissappeared! (Not sure where it all went because ground never looked flooded?)
Luckily I had noticed the water level went down and let cover loose before the snow/ice pulled the walls in!
Now I'm looking to replace liner.
It is an overlap liner with the center +/- 12" deeper than the edges.
Looking for suggestions on where to buy, what type, install tips?
From my reading so far, I'm guessing -
Need to wait for 70/80 deg. days to get here before install?
Going with another overlap liner with a design and new coping beads.
Probably don't need to go with extra expense of expandable liner. Std will stretch? (I don't believe original was a expandable.)
Ramp sand up around perimeter. (I think I read that a strip of vapor barrier between wall and floor is a good idea before doing this?)
Any help will be much appreciated!
Thanks!
Thanks!
