Thread: Multiple-speed pumps and in-floor cleaning systems
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Hi all,
    I think my pump is on its last legs. It's a 1hp single-speed Hayward, and I would like to replace it with a 2-speed motor when it finally kicks the bucket.
    I have an in-floor cleaning system (mfg by A&A) and am wondering if a 2-speed pump on low would work with it, ie would it have enough "oomph" to pop up the heads. I don't have any way to bypass the in-floor cleaners, so my wall returns are one of the zones.
    Does anyone have a setup like this, or experience with the idea? Thanks a bunch.
    Danny
    South Central NJ
    3,192
    Re: Multiple-speed pumps and in-floor cleaning systems
    I don't think low speed will do it. The added head loss when the floor zones may only partially lift the heads and certainly won't provide the velocity needed for the floors to push the floor debris sufficiently.
    A variable speed may reduce your energy costs since they often can push the same amount of water using significantly less electricity. Worth looking at.
    Scott
    Owner of - PoolGuyNJ LLC
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    And if you do go with a variable speed model, I'd suggest NOT using the Intelliflo VF in this application. It will change speeds every time your valve redirects water since your pressure side plumbing changes with every different position. The result is a pump that's constantly revving up and down. It gets distracting. A VS model (Intelliflo VS, Matrix, Stealth, etc.) will just maintain the same RPM regardless of hydraulic changes.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by spishex
    This simple, straight forward answer is the best, shortest explanation I've seen on VS vs VF pumps.
    Perhaps it, in and of itself, should be a sticky.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
