I have an older pool which sucks primarily from the skimmer.
The main drain leads to the side of the skimmer. It sucks a small amount via the skimmer, presumably via Venturi action. I’ve put dye in the main drain to see the flow rate, and it’s very low.
our previous pool (which was newer) had separate suction lines from main drain and skimmer, which obviously sucks a lot more thru the drain.
im considering replumbing my main drain to a separate line to get more even suction, better mixing, and greater control over the system.
Any thoughts?
And whats the logic of main drain running to the side of the skimmer as opposed to its own line?
Any thoughts?
