Hi all,
I posted over the summer about a possible pool build and it is now complete! I am diving into chemicals and took water for our first test to compare my home numbers (using a cheaper kit provided, TF 100 is in the mail) and I was spot on, woohoo! My question is: I've read so much about the nightmare that is too high CYA so I'm hesitant to add it, but it tested at a 1 in our pool. We have an ozone system so while we're currently using the chlorine tablets, we don't use many so I'm guessing won't be getting too much CYA from them built up (?). I've read so much about using liquid chlorine/bleach and thought we'd go that route, but I didn't say a word about it to the guy that did our pool school but he specifically told us not to use liquid chlorine (because the plaster is curing?).
Results:
FC .6 (ozone system so we're only slightly low and chlorine tablets just went into the system a day and a half ago)
pH 8.6 (added 1/4 gallon muriatic acid after the test)
TA 90
CH 138 (we were told not to mess with this yet as the plaster cures?)
CYA 1
tl;dr version: should I add CYA to my new pool or wait a bit? Is liquid chlorine bad for new plaster?
Thanks in advance, everyone! Looking forward to learning more from you all!
Results:
TA 90
CYA 1
