Hello all
We purchased a home (Georgia) with 34,000 gallon gunite/pebbletec pool in October. The pool was cloudy when we took possession and had yellow algea. The pool needed many upgrades which we completed in mid-October including re-plumbing, installing variable speed pump and DE filter.
We engaged a certified pool maintenance company and they started maintenance 10/22. AFter their first cleanup on 10/25 the pool was beautiful. Downhill from there. They added Metal Klear on 11/1 and 11/12. The green tint started after the metal klear.
They are unable to maintain chlorine levels in the pool. In addition to filling our chlorinator they filled both the skimmers to keep up the chlorine. One of their guys want to drain our pool - however our septic drain field is right behind the pool and we have a beautiful 1 acre pond full of fish on the other side.
Today they wanted to add 3 gallons of acid and were not happy when I refused.
Anyone have any idea what might be keeping the chlorine from hanging around or cause the green tint in the very clear pool? The pool is not stained.
Week | 10/5 | 10/25 | 10/30 | 11/1 | 11/6 | 11/12 | 11/13 | 11/20 Pool Guy onsite | 11/20 Browns computer |
Free Chlorine | 1.5 | 0 | 0 | 1.6 | |||||
Total Chlorine | 1.5 | 0 | 0 | 2 | 0 | 0 | 0 | 3.3 | |
Alkalinity | 41 | 80 | 90 | 90 | 100 | 90 | 100 | 0 Total Alkalinity | |
CYA | 128 | 50 | 100+ | 100 | 136 | ||||
Calcium | 100 | 20 | 300 | 160 | |||||
Total Hardness | 274 | 407 | |||||||
PH | 7.7 | 7.4 | 7.4 | 7.2 | 7.3 | 7.4 | 7.6 | 7.2 | |
Copper | 0 | ||||||||
Note | Treat for yellow algea. Add 6 chlorine tabs + 15 pounds of shock. Pool looked beautiful in 4 days | Add 8 chlorine, 6 lbs of shock and 25 calcium. Pool a bit cloudy had rained 2 days | Added 5 chlorine tabs, 1.5 lbs shock and 3.5 bottles of metal klear | Added 12 chlorine tabs, 5 lbs shock. Pool bright green but clear | Added 3 bottles Metal klear | Added 8 chlorine tabs + 3 lbs of shock. Bright green but clear | Added 10 tabs chlorine + 3 lbs of shock. Bright green but clear. The pool company also wanted to add 3 gallons of acid but I refused. | An hour after regular pool company left I took a water sample to Browns Pool and asked them to run through their computer |
