Hmm, I am wondering if you ended up with an air pocket in the motor housing. This would prevent the pump from moving water and resetting the flow switch. Do you have a plunger you can fit over either the main water intake or drain and get water moving through the pipes (saw this idea in another thread in here and think it's a great idea). Or, do you have a sump pump you could drop in with a hose connected and run the hose to the filter inlet to try and force some water through the pump hopefully eliminating the air pocket and restoring flow. Worst case, I would jump the flow switch to at least get the water circulating and get some heat in the water to prevent the tub from freezing.
