Okay my inside aqualink RS4 unit looks just like the one in the picture. It is getting cold and my freeze protect has been used 2 nights in a row.
I woke up this morning and it seemed to be stuck in spa mode and was not circulating the water in the pool.
I tried to turn the spa off (when spa is on, the first 2 buttons are lit red) so I pressed the spa button and it tells me it will turn off in a bit (those black knobs in my pool equipment have to turn and close the pipe to the spa and open the one to the pool). Once that is done I would think the water would then flow to the pool but it just turns the spa right back on.
Yesterday I was able to turn the spa off for the first time, I just kept pressing the spa button and then started double pressing it and somehow I was able to turn it off and then I turned just the pool pump on.
Today I was not able to repeat the same, I had to go outside and put it in service mode which turned it all off then I switched it back to auto and then went in and the freeze protect automatically turned on the pool pump and waterfall which is what I wanted. I didnt want it stuck in spa mode.
Anyone know anything about this?
My temporary solution is to take the spa OUT of the freeze protect, BUT I am not sure if there would then be pipes water is sitting still in and could possibly freeze and burst the pipes.
What I dont want to happen is the freeze protect turn the pool pump on, circulate that, then turn the spa on to circulate it but get stuck in spa mode and then the water in the pool pipes freeze up and burst.
Is there some button combo press I need to do to turn off the spa and move it back to pool?
